CaseySmithersxs
XS650 Junkie
Okay guys, I really dont post questions on here unless I've tried everything I can think of. So here I am. My carbs "mainly left" keep flowing fuel into the main bore of the carb"throat" as I call it, its coming up through the brass fitting that the needle slide goes into. Petcock is OFF and NOT leaking, it drained all the fuel ou the line until its dry. Both float are set to 25.50 which is on the lean side. I also did the clear line test with the carbs level on my bench, the levels were not high "under the bowl flange". New needle and seat on left side, and right needle and seat seem to be performing correct, if so blow into the fuel inlet and the float is resting on the needle, it will NOT let any air through. I've also submersed both float in hot water for a fairly long time, and no bubbles or water in the floats.
So....
Float levels-25.50=check
Needle valves-no air flow when floats are resting=check
Floats-no leak=check
ONLY THING I CAN THINK OF IS THE BRASS PIECE THAT THE NEEDLE SLIDE GOES INTO IS LEAKING, But I dont know if thats even possible. Im out of ideas... Thanks in advance for the help.
So....
