Dieselchanic
Intermittent builder
When I bought my 81 xs650 the guy told me it had a blown head gasket. I didn't argue and didn't even check it out that close because I knew with the parts on the bike it was worth what I was giving for it. So I started checking it out a bit. Pulled the plugs and kicked it over, hot spark. Ok good. I choke it and kick it over for a bit, no love but it's making a whooshing sound as it rolls over. I deduce thus us coming from the crankcase breather (it's wide open). Well that's normal ish. As I continue to kick it I realize this beast is a bastard to kick. It wore me completely out. So it's got a blown gasket but still enough compression to kick like a mule? I gave it some ether and kicked it. It hit and almost threw me... It hits hard. But it hits right before it should cuz it kicks back. Every time. I've read that a stuck timing advance will cause a hard starting issue so I peeked at that. This is what I found:
That's something jammed in there to hold the weights out... Umm??? It's also all rusty in there.
So I'm thinking that even if the gaskets blown if it's got enough juice to crackle and pop on ether it should try to run a little? It doesn't. It just kicks back.
So what do you guys think my problem is? Blown head gasket? It funky timing?
