Sparky
So this past weekend, I took my project bike out for a ride. After a short spin around the block, something started making a loud clanky rattling noise.I immediately pulled over and started looking for a problem. a sprocket bolt somehow backed out and caused some destruction. it caught the chain adjuster, bent it up and spun it around. it also caught the rear fender support and sheared the bolt holding it. It likely bent it up also. While waiting on my friend to show up with a sawzall, i used a chunk of metal i found and a rock to beat the chain adjuster back into place. the sawzall made short work of the ridiculously bent bolt. after that (fix?) i was able to ride it home with no further problems.
I'm not sure how the bolt backed out. i removed them some time back when i cleaned up the rear wheel, but i thought i had tightened them all down and hammered those little lock tabs in place. tomorrow i'll have some shop time, hopefully can start to disassemble and see what all needs fixin. while i'm at it im gonna pretty much check every other bolt that i've ever put a wrench on. this incident was only aggravating, but could have been much worse.
so, picture of carnage and moral- check your important bolts, safety first.
