NewestOnTheBlock
I've been having the worst time getting my bike to run good (1980). After performing the dead cylinder method and using a diy manometer, the bike idles great. Even revs well and returns back down quickly (or normally, i guess).
Whenever I take it on a test run, the first 5 minutes are amazing. After that, it all goes downhill.....
The main problem, is that most of the time the bike's idle will jump up to 4-5000 rpm...Sometimes it will come back down after maybe 10 seconds, lately it just stays up that high. A few times, it even goes higher....to the point where I just have to shut off the bike.
I tore apart my carbs again, this would be the 3rd time in that last 2 weeks. I've done a thorough cleaning job, and replaced the floats. but I decided to look closely at the diaphragms. Sure enough, there are a few holes the size of pin needles.... Maybe 2 or 3 on each carb. Tiny little holes that you wouldn't see unless looking at the right angle with a light.
Obviously i need to replace them. But Is this the source of my problems? could this be causing the random high revs?
