hard_y_rd
XS650 Guru
Arrggh. What do you do when they start stripping out before they get torqued to spec. 84 inch/lbs i believe. Not too much experience with heli-coils or threaded inserts. Its a shitting feeling when they strip. Help.
(note cut the coil on the flat to avoid leaving a bad edge)
Good article yamimoto. Here's more lube/torque chatter:
http://www.xs650.com/forum/showthread.php?t=27533
