dps650rider
My engine recently developed a ticking noise that I cannot figure out that sounds a lot like valves ticking. I have checked and double checked valve clearance and cam chain adjuster, inspected and rebuilt the oil pump, removed the sump and cleaned out and inspected the screen, checked for oil reaching the top end by running it with the valve covers off, blown compressed air through the oiling system, checked the cam chain front bolts.
When I first start it it is very quiet (I have elephant foot adjusters). It makes the noise after it is warmed up at part throttle between about 3500 RPM and 4500 RPM and is very sensitive to throttle position getting loudest at slightly less throttle than is needed to maintain speed in 5th gear on a level road.
If I am on or off the throttle I do not hear the noise. When it is hot I do hear a slight knocking sound at idle that usually stops after idling a minute or two.
Any help would be greatly appreciated since I'm stumped.
