Jaboney
"Storm Rider"
Hi everyone. New here and just picked up a 72 that hardley runs. Its been slightly modified to an ugly chopper attempt. I plan on a Cafe/Brat conversion. This is a great site. Glad to be here. pix coming soon.
Thanks for the info on those lines. I will just snip them in half then they will be vented. That explains the leaks.Those small lines are vent tubes, vented to the atmosphere, don't interconnect them...
Thanks Wesley for the good tech info. I now have much bigger issues with this engine than carburetors. I removed the plugs and did a compression check and found 110 psi in the left. Zero in the right cylinder.The spigots at the bottom of the fuel bowls are overflow lines - lines from same should be routed downward clear of engine. Spigots on the inboard sides of the carburetors facing each other are connected to "share" fuel enrichening circuit (choke, so to speak) of the left carburetor with the right one and the second is for fuel equalization between the 2 - black hoses in your photo. Upper clear line is a vent line - open to atmosphere. And the air filters appear to be something other than stock Yamaha parts..
