I have heard of people using a chrysler Regulator What Gives Is it Better? Cheaper? Or where Can I get one. I think Mine is bad,and If I can get one for Less than MikesXS wants then I am Dialed People Help Me know what the Difference Is.
http://xs650temp.proboards.com/index.cgi?board=Charging&action=display&thread=3473Ok so I guess That I am a idiot I got the Cheap reg thing but your telling me I have to go to radio shack and build a Rec how do I do this remember I am just a guy that paints for a living mech stuff I can handle Electric I can not.
so .. make sure i got this right on 79 an later you can use your original screws , or just with these 2 types as mentioned above advance auto - VR292
napa - MPEVR1010SB
Here is a suggested replacement for the rectifier on 1970 to 1979 XS650's. Go to Radio Shack and buy 2 #276 - 1185 Full Wave Bridge Rectifiers for $3.29 ea.. Wire and mount them as follows:
1. Fabricate an aluminum plate approx 3 X 2 inches. Use .125 aluminum. This is the heat sink.
2. Mount the Rectifiers per the drawing, using heat sink compound between the bottom of the rectifiers and the plate.
3. Solder wires per the diagram.
4. Recommend that you eliminate the plug and connector as they are toast and you have to solder anyway.
5. Solder the wires from the Rectifiers per the diagram to the existing white wires going to the Alternator and plus / minus (Red / Black).
6. Use a heat sink when soldering the wires to the rectifiers.
7. Mount this assembly in the same place as the original, using either the center hole (as shown) or one of the mounting holes for one of the rectifiers.
8. Note: Do not ground the black wire on the mounting screws. The battery box is floating, it is not a ground.
The Radio Shack rectifier is rated at 25 amps. Two of the three white wires go to one rectifier and the other one goes to the other rectifier, so about 10 amps max is going through one rectifier at full load, with the remainder, 5 amps, going through the other.
The "N/C" terminal can be used as a spare in case one of the diodes shorts out in the future. You could "pre solder" a short wire to it so if you have to use it you can just cut and splice the affected white wire to it.....don't even need a soldering iron!
Life is simple: Ride. Enjoy.
you could use three but space comes into it, not much more than the 4" space under the battery box... open air for me, cooling and retains STOCK look and function
why not use 3 rectifiers and are you guys putting this in "open air" or in the round oil cans I see alot using??
http://www.oregonmotorcycleparts.com/index.html
Has anyone had trouble any of thier products ??
John
Problems with my posts lately............. keep having to edit
