Laydout_noma
I have a 75 XS650. My problem is I have an HID headlight and it flickers at idle, as well as my LED tail light. I've been around the block with the charging system on this thing and read a lot of forums about about it. I started with a battery and stock charging system but now it has a Hughs PMA on it with a Sparx cap. Recently I had an issue with the stator being too wide, so I sent all of my stuff to Hugh to be checked and he sent a one of his skinnier stators and checked the system for me so I don't believe my issue is there. However, tonight I did put a very cheap multimeter on it and at idle the voltage was all over the place, anywhere from 5V to 14V. I'm going to check again tomorrow with a much better quality one. As for the only problem I'm having at the moment is my HID headlight is flickering a low idle. This is the second ballast I've had. The strange part is that it'll flicker and once it goes out for a second it'll stay out but once I switch the key off and immediately right back on, it comes back on. I've checked my grounds and rechecked my grounds but nothing seems to help it. I am just looking for any advice on what I could check next to try to fix this.
PS: I do know that the cap is supposed to buffer the AC out of the system but I can see in the rear LED light where it is still pulsing. Just wondering if its normal for it to flicker slightly.
