XS650 Forum
Go Back   XS650 Forum > General Discussion > The Garage
Register FAQ Members List Search Today's Posts Mark Forums Read
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries, but you have to register before you can post or view attachments. It’s free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
Notices
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Topics
Threads in The Garage can also be viewed by Topic.
Reply
Thread Tools
Old 01-18-2010, 08:48 AM   #1
doubletrouble
doubletrouble's Avatar
Default adding second brake caliper-?
I bought a brake rotor for the left front side of my 81' H from e-bay recently. It was listed as a late seventies xs650 and it matched the overall dia. and the bolt pattern was the same. When I got it in the mail it had a thinner braking surface,but I thought i could live with it, but the left side brake caliper bracket is hard up against the rotor surface. its just a little too wide overall?
My question is, do I need to find an 81' front brake rotor or is there any production years that will work? Did Yamaha make rotors with thinner braking surfaces?
Any help would be great!!
DT
(winter is half over!!)
doubletrouble is offline   Reply With Quote
Old 01-18-2010, 10:00 AM   #2
inxs
XSively Addicted
inxs's Avatar
Default Re: adding second brake caliper-?
- youre correct, there are different diameters, thicknesses and offsets... i dont know very much about this topic yet so cant specifically help you, there is some info filed in the tech section under 'brakes' that may help you...one day, hopefully, someone will pull all the info together and write the brake bible
fear is temporary, regret is forever
inxs is offline   Reply With Quote
Old 01-18-2010, 10:25 AM   #3
grizld1
grizld1's Avatar
DT, you have an incorrect part there. The same front rotor--Yamaha part no. 1J3-25831-00-00--was used on all XS650 models equipped with 35 mm. forks and floating calipers, from the 1977 D-model through the close of production.
grizld1 is offline   Reply With Quote
Old 01-18-2010, 12:40 PM   #4
doubletrouble
So grizld1, I think you are saying that any front rotor from the 77 D-model and later will work,is that right? I havn't seen anybody listing rotors with Yamaha parts numbers on e-bay yet. Anybody else have any imput on this? I know I'll be asking sellers for more info this time.
thanks!!
DT
Old 01-18-2010, 02:07 PM   #5
KevC
KevC's Avatar
Found some basis information which seems to be very similar to the Minton mods here
http://www.biker.net/650/dual_disk.htm
Im sure there used to loads on this subect, I looked at loads of stuff before converting mine to a Fazer Blue spot Caliper, better braking & much less unsprung weight But cant find what I remember seeing now
Maybe it was on 650Rider
KevC is offline   Reply With Quote
Old 01-18-2010, 03:44 PM   #6
KevC
KevC's Avatar
As grizld1 said, part number for disc is 1J3-25831-00-00 from 77 on
Here are a few that are very similar part numbers, the ones in blue are an exact match.
Cant be sure about others but sure I read somewhere a SR500 disc fits but is 3mm thinner
EBC do a decent replacement part # MD2024LS (left side) MD2024RS(right side)
1J3-25831-00-00 Disc, Front Brake XS11002H9, XS11002H9, XS11003X0, XS11003X0, XS1100E, XS1100E, XS1100F, XS1100F, XS1100G, XS1100G, XS1100SF, XS1100SF, XS650SG, XS650SG
(Also XS500, XS750 77 on)
10M-25831-50-00 Disc, Brake XJ1100J
1J3-25831-50-00 Disc, Brake Rear XS650SG, XS750-2D, XS750-2D, XS750D, XS750D, XS750E, XS750E, XS750E-227501, XS750E-227501, XS750F, XS750F, XS750SE, XS750SE, XS750SE-311211, XS750SE-311211, XS750SF, XS750SF, XS850G, XS850G
3H5-25831-00-00 Disc, Brake XJ1100J, XS1100H, XS1100H, XS1100SG, XS1100SG, XS1100SH, XS1100SH
3H5-25831-10-00 Disc, Brake XJ1100J, XS1100H, XS1100SG, XS1100SH
3J2-25831-00-00 Disc, Brake XS850H, XS850H, XS850SG, XS850SG, XS850SH, XS850SH
3J2-25831-10-00 Disc, Brake XS850H, XS850SG, XS850SH
4H1-25831-00-00 Disc, Brake XS850LG, XS850LG, XS850LH, XS850LH
4H1-25831-10-00 Disc, Brake XS850LG, XS850LH
4H3-25831-00-00 Disc, Brake XS11005K7, XS1100LG, XS1100LG, XS1100LH, XS1100RH, XS1100RH
4H3-25831-10-00 Disc, Brake XS11005K7, XS1100LG, XS1100LH, XS1100RH
4H3-25831-50-00 Disc, Brake XS11005K7
4W1-25831-50-00 Disc, Brake XS1100LH
Old 01-23-2010, 09:02 AM   #7
doubletrouble
thanks kevc, thats some great info. new(used) rotor is on its way!!
anybody need a front brake rotor from a mid seventies xs650? in perfect shape. $25. includes shipping
DT
Old 01-23-2010, 11:18 AM   #8
KevC
KevC's Avatar
DT
Also have a look at this thread by 80xs650
Rotors that fit XS
Old 01-31-2010, 10:29 PM   #9
XSLeo
XS650 Junkie
XSLeo's Avatar
Some of the xs1100 rotors are 5 mm thick instead of 7 mm thick. The ones I used on my 75 are 5 mm thick. On the left side is where the axle clamps to the fork. loosen the fork clamp bolts and move the fork over enough to center the caliper over the rotor. Tighten the clamp bolts. Good to go.
75 XS650B with a few mods, Dual disc brakes up front, Disc on rear, Pamcopete Ignition with the green coil, Radio Shack rectifier and Chrysler regulator, LED tail/brake and turnsignals
XSLeo is online now   Reply With Quote
Old 02-01-2010, 01:00 AM   #10
inxs
XSively Addicted
inxs's Avatar
- if i understand right youre suggesting pinching the forks inwards to centre the discs...wouldnt that upset the long term fork dynamic and increase wear on the seals?
Old 02-01-2010, 06:41 AM   #11
doubletrouble
I would never do that. By bending the fork outward in order to center the rotor in the caliper it would increase play for the speedo drive exposing the wheel bearing abit. Not to mention messing with the fork and possible handling issues.
I would rather keep a single brake rotor than have to worry about all that crap...
Old 02-01-2010, 09:07 AM   #12
KevC
KevC's Avatar
Quote:
I believe some rotors are thinner (SR500? for one) but as the caliper on the XS is floating & even with a 2mm thinner rotor, that only puts it only 1mm off centre, assuming the rotor offset does not compensate for this. The floating caliper would certainly compensate for this, otherwise you would never be allowed any wear in your brake pads. (one pad is fixed and the whole caliper slides when braking)
Pays to keep that sleeve, bolt and rubber cover greased up so the caliper is free to move
Old 02-01-2010, 09:13 AM   #13
grizld1
grizld1's Avatar
The correct procedure for installing a thinner rotor is to install spacers to reposition the caliper mount to reduce the distance between the rotor and the passive pad. The piston will reposition itself, taking care of the active pad. It isn't difficult; just get the passive pad as close as you can to the rotor without dragging, using new pads.
Old 02-01-2010, 01:26 PM   #14
650Skull
XS650 Junkie
650Skull's Avatar
The XS650 rotor is is not to be used if less than 6.5 mm thick. Why ? these rotors do warp if they are to thin so why would you put on a thinner rotor.........An SR500 weighs a lot less than a XS650........... I would not like to have the weight difference of the 2 calipers on the front wheel, also an insurance concern if one rotor was undersized
To old to die young
650Skull is offline   Reply With Quote
Old 02-01-2010, 01:51 PM   #15
grizld1
grizld1's Avatar
Second that, Skull! You'd want the rotors matched on a 2-disc setup, that's for sure, and even with light rotors that's a lot of unsprung weight added to the front end. Much can be done to improve stopping power with a smaller MC, braided stainless lines, and upgraded pads. But minimum thickness has less to do with bike weight and caliper design than with the design and composition of the rotor. I used a slotted 5 mm. OEM rotor from an XS850 IIRC for some years before switching to a still lighter semi-floating rotor from Mike's XS--a very good item, BTW--and finally to a full-floating Brembo rotor from 650 Central. You can really feel the weight difference, and stopping power with Vesrah sintered pads and 11 mm. Brembo MC is light years ahead of OEM.
Old 02-01-2010, 02:22 PM   #16
KevC
KevC's Avatar
Why even bother going for a twin disc set up, with all that added unsprung weight, when so much can be done to improve the single disc set up.
Like grizld1 says
Quote:
Originally Posted by grizld1 View Post
......... and even with light rotors that's a lot of unsprung weight added to the front end. Much can be done to improve stopping power with a smaller MC, braided stainless lines, and upgraded pads. ........and finally to a full-floating Brembo rotor from 650 Central. You can really feel the weight difference, and stopping power with Vesrah sintered pads and 11 mm. Brembo MC is light years ahead of OEM.
Even better with a caliper off an R1
HERE
Old 02-02-2010, 01:06 AM   #17
XSLeo
XS650 Junkie
XSLeo's Avatar
I'm using two 5mm thick XS1100 rotors. The right side lined up ok. The left side was off almost enough to rub on the caliper bracket. I moved the forks about 1 to 1.5 mm. I don't think this will cause any handling or wear problems. It handles just fine, to soon to detect any wear.
The European bikes came with the dual rotors. Perhaps some one from there has a manual that explains just how the second caliper lines up.
I have an '03 Harley Super Glide Sport. It has dual disc on front. In the repair manual it explains how to line the rotors up. With everything installed you tighten the axle nut, this lines up one rotor. The other rotor get lined up by putting a 7/16's drill bit through the hole in the end of the axle. Move the fork over till it just touches the drill bit, tighten the clamp bolts. If this works on the Harley forks it should be ok on our 650's.
I agree that a single disc setup has certain advantages.I like the look of the dual setup, mine works very well.
Like everything that we do to our bikes a single or dual setup is just personal preference. Keep a bike stock, chop it, tracker, bobber, hardtail whatever, it's just personal preference.
Old 02-02-2010, 01:12 AM   #18
XSLeo
XS650 Junkie
XSLeo's Avatar
Doubletrouble, moving the fork over on the axle won't expose the bearing or effect the speedo drive. All that is pulled to the right when you tighten the axle nut.
Old 02-02-2010, 01:19 AM   #19
inxs
XSively Addicted
inxs's Avatar
- european models have 2 x 267mm disc with floating pad mounts in the calipers...no need for fork pinching when setting these up
Old 02-02-2010, 03:12 AM   #20
650Skull
XS650 Junkie
650Skull's Avatar
Two important things here.
1: the distance from the back, ( the face that sits against the hub), to the back of the rotor, determines where the rotor sits in relation to the caliper.
2: tighten the axle nut before you tighten the axle clamp on the left end of the axle. If you tighten the axle clamp first, then tightening the axle nut will pull the bottom ends of the forks together.
To old to die young
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
Fazer Blue Spot Caliper KevC The Garage 60 04-10-2010 10:45 AM
Wanted - mag rims (19/16) and rear disc caliper setup slothy Classifieds 0 01-20-2010 02:56 PM
Wanted - XS2 Front brake caliper Tim Louth Classifieds 2 01-10-2010 03:02 AM
Tags
brakes, caliper
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Copyright ©2000-2010, Jelsoft Enterprises Ltd.
Copyright © 2009-2010 XS650.com, Trav, LLC
