I just hooked up my timing gun, and I do believe I'm off. The green line indicates the mark shows up while in lower rpm (sorry, I don't run a tachometer, so I'm guessing where 1200rpm is) and the red line indicates it at higher rpm (3200 rpm?)
Does this mean I need to retard it or advance it?
Also, should the mark match the firing mark or TDC mark?
I also took a pic of my points. I have figured out the 2 screws to loosen and where to adjust, but which way do I twist in order to advance/retard?
Thanks in advance
Thanks in advance
