XS650.com
Forum Search: Advanced
Go Back   XS650 Forum > General Discussion > The Garage
Register Forum FAQ XS650 Tech Members List Search Today's Posts Mark Forums Read Donate
Welcome to XS650.com!
XS650.com is dedicated to the Yamaha XS650 twin motorcycles and to the people who love to ride, restore, and customize them. As a guest you can view the forum and photo galleries full of xs650 choppers, bobbers, trackers, cafe racers, and restorations, but you have to register before you can post or view attachments. Itís free and only takes a minute. Proceed to registration. (This notice will go away once you log in)
Notices
The Garage Motorcycle Related Discussion (Yamaha XS650, other makes and models, and anything else motorcycle related including tools and gear)
Reply
Thread Tools Search this Thread
Old 03-16-2011, 02:44 PM   #1
dr mac
dr mac's Avatar
Default locked gas tank ( no key ) Where to get one?
I have a xs gas tank with a locked cap and no key
No. on lock is 3185 is there somewhere to buy a key that fits.
4 years in government office and 4 years in prision sounds fair to me .
Dr mac
dr mac is offline   Reply With Quote
Old 03-16-2011, 02:51 PM   #2
C-Los SD
C-Los SD's Avatar
Default Re: locked gas tank ( no key ) Where to get one?
Your best bet is just to get a used/new gas cap with keys. Use mini long flat screw driver to push the latch under the cap and replace. It's a pain, but I had to do it twice on xs750 tanks. Easier done if you take the tank off.
C-Los SD is offline   Reply With Quote
Old 03-16-2011, 03:13 PM   #3
Travis
Staff Member
Travis's Avatar
Bring the tank to a lock smith and see if they can make you a new key.
- Travis
Travis is offline   Reply With Quote
Old 03-16-2011, 03:18 PM   #4
jayel
#9 Guru 74 TX650A
jayel's Avatar
take your key number to a yamaha dealer
I actually read this post and now my comment makes absolutely no sense.
Where are we going and why are we in this handbasket.
Hobbies... Avoiding hard work and pain
1987 XLH1100, 1980 XS1100, 1978 SR500, 1980 Yammahopper, 1966 Aermacchi/H-D M-50
jayel is offline   Reply With Quote
Old 03-16-2011, 03:24 PM   #5
dr mac
dr mac's Avatar
Just taken the lock out . Is there a way to remove the tumblers so any key will work?
Dr mac
Old 03-16-2011, 04:09 PM   #6
5twins
XS650 Guru
5twins's Avatar
Yes, you can "re-key" it to work with any key that will insert into the lock. The problem is, Yamaha used up to 4 or 6 different key styles. Some offset left, some right, some had narrow grooves down the sides, some wide. You need to find the style that will insert into your lock.
The lock cylinder itself uses spring-loaded sliding plates as "tumblers". The top 4 or 5 engage the key and work the lock. They have rectangular cut-outs in them for the key to pass through. The height of the cut-out determines what key notch they work with. The one at the bottom locks the cylinder into the housing. You need to reach down into the bottom of the lock with a pick of some sort and slide that bottom plate over to release the cylinder from the housing.
Once you have it out, you'll notice that all the plates stick out one side of the cylinder. Inserting the right key will pull them all down flush so the cylinder can be turned. The wrong key may pull some flush but the rest will still stick out above or be pulled too far and stick out the bottom.
If you're lucky, you can just swap some of the "wrong" plates around and things will line up. If a plate pulls too far, you can file the cut-out larger so it pulls flush. If it doesn't pull enough, you need to replace the plate or remove it completely (leave it out).
'78E Standard and 4 Euro twins
5twins is offline   Reply With Quote
Old 03-16-2011, 04:26 PM   #7
BigJimmyW13
XS650 Guru
BigJimmyW13's Avatar
Couldn't you just take all mechanisms out to work with a knife if need be?! My CX500 whenever I bought it I asked for the ignition key. The guy smiled and said just turn it with your house key and it'll work.
My Rides
31yo XS650 Rephased 750
32yo Honda CX500 bobber
25yo Harley Evo Mutant
7yo Buell XB12R
BigJimmyW13 is offline   Reply With Quote
Old 03-16-2011, 04:51 PM   #8
Travis
Staff Member
Travis's Avatar
5twins, great information!
- Travis
Old 03-16-2011, 05:11 PM   #9
dr mac
dr mac's Avatar
Yes I just did . Once I remove the part that has the tumblers. I turned it over and there was a spring loaded release on the bottom side . I used a pen knife to push in the clip and pushed out the tumbler carrier . Once I removed them I put it back together and used a old model (70-80s ) chevy door key.
One more item taken care of .
Thanks
Dr mac
Old 03-16-2011, 05:21 PM   #10
BigJimmyW13
XS650 Guru
Problem solved!
My Rides
7yo Buell XB12R
Old 03-16-2011, 05:54 PM   #11
pamcopete
Ride.Enjoy.Life is Simple
pamcopete's Avatar
www.motorcyclekeys.com
pamcopete is offline   Reply With Quote
Old 03-18-2011, 04:43 PM   #12
PhatTony
I love twins
PhatTony's Avatar
eBay usually has a couple guys selling pre-cut keys. This guy has your key number
72 XS2 Show Restoration in process
80 XS650 Rephased Chopper
79 XS650 New project TBD
72 XS2 Factory Spec Restored
XS2, XS1B, and XS1 Projects.
PhatTony is offline   Reply With Quote
Old 03-19-2011, 10:19 PM   #13
XSLeo
XS650 Guru
XSLeo's Avatar
I lost the key for my 75, I removed the tumblers from both the tank and seat locks. I replaced the switch with one from the farm supply, same switch they want $40 for in the catalogs I got for $16.
I use any key to open the tank and seat.
The only way you can find out if you can do something is to try.
75 XS650B with a few mods, Dual disc brakes up front, Disc on rear, Pamcopete Ignition with the green coil, Radio Shack rectifier and Chrysler regulator, LED tail/brake and turnsignals. 750 kit,1.5 headepipes, Emgo shorty mufflers.
XSLeo is offline   Reply With Quote
Old 03-20-2011, 04:06 PM   #14
bluebikerblan
Geezer
bluebikerblan's Avatar
Quote:
Originally Posted by pamcopete View Post
This gent, John Blankenship is the best going. I've used him for years now. Great service and never had one that didn't work. Face number, model & year. Blue
bluebikerblan is offline   Reply With Quote
Old 03-11-2012, 04:34 PM   #15
glennpm
Another Old Biker Nut!
glennpm's Avatar
I took a few pics this morning to add some pictures to the words.
You need a pick like I've shown or something similar to push the bottom retatining plate over before the tumbler can to pushed out. I used the pick and a small screwdriver to put pressure on the back of the tumbler to push it out. I also held the spring tension off the closer latch in the open position to keep pressure off of the tumbler.
You can see how the key makes all the plates flush with the barrel. There is also a picture of what the plates look like.
glennpm is offline   Reply With Quote
Old 03-11-2012, 05:41 PM   #16
5twins
XS650 Guru
5twins's Avatar
Thanks for those. That's something I never did get any pics of. The seat lock will be quite similar. The ignition switch is more complicated (to make it more secure). It has more sliding plates.
Old 03-11-2012, 05:53 PM   #17
gggGary
Old guy, NO expert.
gggGary's Avatar
Nice gas tank!
"The goal of the forum is sharing our experiences and what we've learned,
not dismissing the ideas of others"
gggGary is offline   Reply With Quote
Old 03-11-2012, 05:59 PM   #18
glennpm
glennpm's Avatar
Isn't it though?
Old 03-11-2012, 07:26 PM   #19
jchrisk1
XS650 Junkie
jchrisk1's Avatar
The plates in my lock must be taken out. Last summer I was about 80 miles from home and stopped for gas. I didn't have my gas cap key with me. I usually leave the ignition key in it and I don't have it on a keyring. I didn't know what I was going to do. So, I pulled out a slim flat blade screwdriver and it turned with no problem. Thankfully.
78 SE, BS38's, Pamco, Stock Charging System,
jchrisk1 is offline   Reply With Quote
Old 03-11-2012, 07:52 PM   #20
pamcopete
pamcopete's Avatar
Well, I decided that using a key on the gas tank was a pain so I modified my lock with a metal tab that I just press to open the tank. I left the non functional lock there for appearance and to maybe fool a siphoner, but I don't really care if the gas is stolen.
Reply
Similar Threads (based on keywords)
Thread Thread Starter Forum Replies Last Post
For Sale - YDS7 Tank, Benelli Tank, Bobber Controls, XS special tank and rear tire twinsarehot Classifieds 14 03-12-2015 12:54 PM
Tank Coatings and new tank Renegade600 The Garage 21 03-20-2011 08:54 AM
suggestions for freeing up a locked motor danno The Garage 30 03-01-2011 04:20 PM
Wanted - Wassell Tank - The gas tank Blues.. Simple Bob Classifieds 13 09-14-2010 10:05 AM
after clutch adjustment kick totally and solidly locked up eosdelb The Garage 4 08-20-2010 05:19 PM
Tags
key, technical
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
