Hello,
I have a 1970 XS1 that's not charging enough.
Everything is pretty much stock. Battery Voltage is around 12 volts. When it runs I'm down in the 11 volt range. Thought it was a rectifier so I created a new one, no difference.
I also have an XS2. I have tried swapping the XS2 regulator, voltage regulator. No difference. Exchanged the rectifier from the xs2, no difference.
I ran all of the tests on the components via the clymer manual that I have. All tests on the voltage regulator were within range.
Saw some tests on youtube. The energized stater will pull a wrench in when energized. The voltage to the outside brush on the stater is around 7.5 volts.
I have the cap to the voltage regulator off and have moved the points up and down to get maybe 1/2 a volt difference. I have tried adjusting the set screw and nothing has really changed.
Any other tests or changes you could recommend will be welcome.
Regards,
redbug2
Regards,
redbug2
