corbshere
I have a 1972 xs 650 .....The master cylender plunger assembly needs replacing. I pulled the brake line,removed the brake switch,took the assembly off the handle bar,now I can't get the brake lever off the master cylender so I can get at the plunger mechanism. Aparently the factory pressed a bronze/brass sleave into the lever pivot mounting hole and threaded that. So with that bushing in place you cannot get the lever off? I mean put aside the fact that my master cyl.is kaput,if I had a broken brake lever I don't see how they would replace that lever! ? Is there a method to removing this press fit bushing? I wanted to keep it all stock but mikes xs does not offer a stock '72 master cylinder replacement,and i have no where else to turn. any Ideas? help!!
