BMWDR1
XS650 New Member
Fairly Stock 1975 XS650 Twin, Fresh paint,Tires,Shocks,Fuel valve,Battery,voltage regulator-rectifier,Wiring & fuses
Plugs,Boyer-Bransen Ignition ,factory Oil screens,520 Chain & Sprockets.
1 Year old VM 34mm Mikuni Carbs. The Head pipes and Mufflers are from "650 Central"
and have the diode inserts in them . Bike runs and sounds real good !!!
The wiring harness has been simplified and modern blade fuses are used along with a late model rotor-stator
& regulator-rectifier installed. Electric starter has been fixed to work reliably and has kick also.
Has K&N style air filter pods,And 13k on the od. Needs very little to be perfect.
For a 35 year old bike it is in pretty darn good shape.
$2800 ONO , bmwdr1 at yahoo dot com. I answer email first
seven2 seven nine 3 four thirty-eight 6 one
