bartender
This bike has been sitting in a garage for 2 or so years. I need the space, so maybe there'll be some interest here. It's a 1979 Special that was highly customized with some very cool bits and pieces. I have an expense record for everything put into it for anyone interested.
First the bad:
Hasn't been started in 2 years
Has an oil leak
The good:
Clean title
Custom exhaust
19” Rear wheel
XS500 Tank
Rear axle
Headpipe Gasket
Swingarm Bushing
Tach
Clutch cable
Throttle cable
Speedo
Gasket-carb holder
Fork seal
Regulator/rectifier
UniPod Filters
19” wheel conversion
520 Chain
Front Sprocket
Rear shocks
Swingarm Bolt
Swingarm bearing kit
Breather filter
Gasket Set
Steering bearings
Tomaselli Clip ons
Torazzi Rearsets
PamCo Ignition
Brake Pads
Plug wires
Grips
High output coil
Throttle sleeve
Plug caps
Headlight
Taillight
Headlight brackets
A123 batteries
Tires
Header wrap
Oil sump filter
Heiden Oil Filter kit
I'm sure there are some things I've forgotten to list, but I think you get the idea. Also comes with an engine stand.
Looking for $2500 obo
First the bad:
Has an oil leak
The good:
Clean title
Custom exhaust
19” Rear wheel
XS500 Tank
Rear axle
Headpipe Gasket
Swingarm Bushing
Tach
Clutch cable
Throttle cable
Speedo
Gasket-carb holder
Fork seal
Regulator/rectifier
UniPod Filters
520 Chain
Front Sprocket
Rear shocks
Swingarm Bolt
Breather filter
Gasket Set
Steering bearings
Tomaselli Clip ons
Torazzi Rearsets
PamCo Ignition
Brake Pads
Plug wires
Grips
High output coil
Throttle sleeve
Plug caps
Headlight
Taillight
Headlight brackets
A123 batteries
Tires
Header wrap
Oil sump filter
