1981 Loom Mods, Electric Start.
TheRhino
XS650 New Member
Hi All,
I am currently modifying the loom on my 1981 special and have removed all the unwanted wiring, clocks, indicator circuit, safety relay, reserve lighting gear. I just got her to fire up on the kick today but my electric start is still not working. With every thing removed I have 3 wires left which I cant find a home for and hope this is my problem...The blank/yellow wire and also the blue wire on the cuttoff relay, the blue wire is spliced in 3 and also goes to the altenator and the loose end is the neutral indicator light, and can be removed, is that correct??? What is the function of the black/yelloow wire???? I also have a blue wire coming from the key switch and have no idea where that goes either, any help would be greatly appreciated.Thanks!
Mark.
Got that all sorted, the blue and the black/yellow wires can be removed, the blue from the key switch is for the lights, electric start was not working because I sprayed the handle bars and lost connection to ground.....thanks for the help!
