I have stock xs650 I have brought out of moth balls after sitting 24 years. Cleaned carbs. , new battery, got it running. Had to really turn idle screw up from where it was set but it idles fine. First gear, give it gas and it sputters then takes off, 2nd ,3rd same thing. Has electronic ignition. Rode it a bit day before, went out to start yesterday and battery was run down, starter solenoid barely made a click. Put charger back on battery, charging up fine. Noticed headlight seemed dimmer then it should be, I think, when running. Ignition is probably original, 37 years old. What do I need to replace and where is the mag. located. Do I need new coil?? I found what I think is coil under seat. Any help would be appreciated. Just got new tires, helmet, insured and plated. I want to go riding with my son before it gets cold. Thank you for your help. PS. Is there anyone close to Trafalgar Indiana on here????
