funky
XS650 Junkie
Hi all just a quick question .
I had intermitent idle back fire running lumpy then fine , bit all over the place ,,,I checked all the obvious stuff then found that where the regulator rectifre connects to the loom the connector had melted near the middle I changed the connector and then checked the battery charging rate and when i rev the engine about 3 to 4 thousand RPM the volt meter is touching 20.5 volts when the engine is idleing 1300 14.to 15 volts .
My question...... is this right .my haynes book says 14 to 15 volts at 2000rpm i thick.
All the best Funky
All the best Funky
