jimmybrown78
I have a 21 inch front drum wheel that came on my chopper build and I am 90% sure it is a xs400 hub (15mm axle). The wheel bearings have been changed to xs650 because the wheel was on a 17mm axle mounted to the forks. I have one question, Isn't there suppose to be a spacer in the middle of the hub between the 2 wheel bearings.
I took the wheel off to try and measure to get some spacers made and I looked between the wheel bearings and there isn't a spacer. There are casting stops that keep the bearings from being pressed in to far.
The wheel was rebuilt and brand new 650 bearings are installed, just trying to make sure that it is safe and if I need to get a spacer fabricated.
Any help or knowledge would be great. I really like the look of this wheel but my knowledge of front drum wheels is very limited.
