Hi gents, as you can guess by the title my 277 pamco is not firing the LHS coil, I am wanting to know if anyone has any resistance/ohm readings so I can do some testing, this will help to determine the cause of failure and allow me to keep this one as a spare, as I have ordered a new one from Pete.
My bike is a 277 rephase with a pma conversion, kick only with a sparx capacitor, it has been running happily for over 12 months.
The rhs still runs perfectly well and the pma is still charging at a healthy 13.5v. Neither of the pamco circuit boards are burnt out, however one of the diodes on the LHS seems to have a small irregularity compared to the RHS.
[/IMG]
[/IMG]
[/IMG]
Failure occurred running errands around town, with no prior warning. Not sure if any other members have had this before with kick only bikes, but it is the only difference I can find between the 2 x circuit boards. I have tested resistances of the diodes (not removed from the board) & they seem to all be the same. From what I have seen most Pamco failures seem to be caused by ignitions being left on etc...and that they are a fairly robust system.
Both coils are getting power with the engine running, there is no broken wires/terminals etc, and nothing looks burnt.? All components have been swapped over to the RHS & still work fine.
Any assistance appreciated, as I am starting to scratch my head trying to determine the cause of the failure..?
Regards.
Regards.
