I took apart the left fork from the 76 I am working on.
There was about a teaspoon of oil left in it and the damper is worn around the top edge (just before the big holes at the top). I am assuming it became worn/damaged due to lack of oil and I am assuming that the right side will be similar once I get to it.
Is the damper still useable? All the other internal parts appear ok.
However, the lower leg has some damage around the edge of the upper opening, above where the seal fits. I don't know what the PO did to cause this, but there is a big piece taken out of it. The lip looks relatively intact though - I think it should probably still seal once refurbished, but it looks kind of nasty (it'll be covered by the dust seal though).
Given these issues, would these forks still be serviceable once they are cleaned and reassembled? In general, do guys opt to switch over to 35mm forks from 34mm? 35's just seem more plentiful on ebay for replacements and parts. If I found a set of 35's, would my original trees still work (what's 1mm between friends?!)?
Sorry for the blurry pix - camera sucks - but I think you can see what the problems are.
Thanks.
R
Thanks.
R
