Bought these awhile back. Totally neglected.
It took a bunch of carb cleaner and soak time just to get them apart.
Finally got them all together and on the bike.
Pods and open slash cuts.
New o-rings under the mix screws.
45 PJ
135 MJ
One shim under the Needle.
New float seat and needle.
Floats (plastic) at 22 mm.
It started on the 4th try after tinkering with the idle position.
Synced carbs.
A short (10 mi) test ride. The throttle hangs a little over 3K when shifting through in the 3-5k (mid range?) but can be powered/geared down and will idle then.
Back in the barn it will start and idle. Blip the throttle and stay below 2200 and it will fall to idle.
Take it over 2500 and it revs to 3200 and hangs.
What is the silver bullet?
When I get it ironed out I will post.
In the mean time what say you? Where does the problem lie?
45 PJ
135 MJ
Synced carbs.
