jakobgoodnessgracious
Hello everyone, this is my first post on here. I just got my bike a little over a week ago. It's a 1974 TX650.
I was having trouble with it dying at low range when I was trying to engage the clutch and take off. Also, after it would die I couldn't start it up but once more otherwise it wouldn't start after that. I decided to clean the carbs and I bought a tender charger to reinvigorate the battery.
I ended up getting some fuel in the oil so what I did was changed the oil, bought an oil filter (got the wrong one so I still have to exchange that for the right one), and changed the spark plugs (they were a dry grey color). I also replaced the float bowl gaskets as they were both cracked.
This got the engine starting up just fine.
To the issue:
Now however after taking it out for a ride around the block I noticed that when I disengaged the clutch the engine would hang at its current rpms. If I downshifted and engaged the clutch that would help slow it back down. Maybe it's because I'm new to motorcycles, but in my car when I disengage the clutch the engine returns back to idle. I feel like that's how it's supposed to work.
After riding it around the block and coming home to park, the engine was in neutral but it was doing the sort of 'hunting' for idle. It revved up on me for no reason. The throttle was disengaged.
I feel like I cleaned the carbs well and put everything back together correctly. I have looked online and found that my bike is probably running lean. Adjustments-wise, I don't know how I can fix this. I looked at the sync in the manual and apparently to adjust the sync, you just adjust the throttle cables. I think they should be fine from observing them just by looking at the cables anyway.
As far as I could tell when cleaning the carbs, the butterflies were working just fine. I am thinking maybe the vacuum in the diaphragm isn't pushing the needle/piston housing back down. But I don't see why it would be having issues either as everything looked fine to me when I cleaned it.
I saw that you can check the boots by spraying carb cleaner on them while the engine is running and listen for a difference. However, I don't see much of a boot with this bike. It seems just like the intake is directly connected to the back of the carb.
Sorry for being long-winded, I just want to be thorough as this is bothering me and I want to fix it as soon as possible.
Posted a bunch of pictures so you can see what's going on. Not sure if any of it helps, but I figure it can't hurt.
Thanks for any help!
Jakob
To the issue:
Jakob
