Shifty2932
So I have found out that I have a set of 78-79 BS38 carbs. I am running stock setting for the carbs, I have crappy kn pod filters, and running drag pipes with thumbscrews for baffles. Trying to wr my head around this small engine stuff. Diesel and jet engines are much simpler. I know I need to change the pods and I'm going to be getting uni pk82 for that. The plugs right now are black! That would be a sign of running to rich, correct? So I would not want to increase jet sizes, right? As this would cause an even richer environment?? Reading other posts I realize drag pipes are not best for mid range rpms. However I feel that when I am in 4th or 5th gear and want to get up go I should just be able to roll on the throttle. Right now this is not the case. I grab a handful of throttle and nothing, until I roll of about 1/8 or so and the r's start to pick up and away I go. But this is not the case all of the time. The grade of the road must be advantageous for this to happen. Any suggestions on what to do to get some power / torque in the mid range?
