552 flasher relay question
Ksboy19
Bonner Springs, Ks
I found 2 flasher relays layin around and im looking to wire up my turn signals, they have 2prongs each, and I have one for each side of the bike. But my problem is I cant figure out what order to wire them up in, I mean is it 12v to what on the flasher to where to the signal to the switch, so lost on this one. Any help would be nice, Thanks guys!
Ksboy19,
Here is a wiring diagram for the stock turn signals:
You do not use the wire to the cancellor with the 552 two prong flasher. Only one flasher required for both sides.
Thanks Pete! Ill give it a try, Im just not sure if thatll work cause im pretty much building my own turn signal harness, nothing is stock on it.
