650 coil mystery please help
Backyard Built
XS650 New Member
Space
i have a 1979 xs650 and whenever i turn the key to on the coil pulses spark to both plugs in a consistent rhythm like pattern like
ive checked fuses and ignition and searched for loose or broken wires so far no luck, any one run into the same problem
Howdy,
I've not experienced this phenomenon personally, but I believe it can occur if the engine cases do not have a good ground - continuity back to battery negative.
What ignition system is present (some do that normally).
hey thanks for the info , i ended up buying a new battery and installing a voltage meter nd found out that my battery is being undercharged , my stator is olny putting out 12.5 volts so im going to take it apart and see what mite be causing the issue ,
Often the Rotor . and please check the brushes
