hotshoe
OK Guys, I need your help. I am building a tracker starting with a 1979 Special. I started the engine last week using the stock ignition switch and all the stock instruments. Everything worked great, all lights and the charging system working fine. I wanted to clean up the front end a bit so I removed the stock speedo and tach, I also removed the little panel that tells you when the blinkers are on or your brake light is not working. I took the locking mechanism off the stock ignition switch and relocated the switch placing a plastic disc behind the switch so the wires would not touch anything and short out. Now when I turn the key on the red wire from the switch is getting hot. It"s hot all the way back to the fuse. Not melting yet but pretty hot. And my charging system is not working. I did the slap test and that works fine. I was wondering if I need to ground the key switch or something? Do I need to jump certain wires or something because I no longer have the instruments connected. I am completely in the dark when working on electrical problems but I know you guys can help me fix the problem. Oh and I don't have any turn signals hooked up yet either. Maybe that has something to do with it. Thanks ahead of time because I know someone can help me.
