For Sale - 72 bobber
MrYeats
MrYeats
Texas
For sale is my 72 Anomoly. Frame and motor have 72 serial numbers though the frame appears to be that of a 74 as it had the tubular rear footpeg mount. Engine and frame are matched serial numbers. rear grab rail cut off, rear footpegs cut off, centerstand cut off, and I still have those parts to be included. The seat is from a Sportster. The bars are 36" motocross, The exhaust is 2 to 2 both right side with reverse cone megaphones. The motor is stock with bs38 carbs. The rear wheel is 16" with new VeeRubber tire and the wheel was sent to Buchanans for custom made 8ga stainless spokes, and since it came off a xs400, the axle was customized to fit.Had to be machined Shocks are from Suzuki 800 Marauder, front forks resealed and new oil.Oil sump filter and side filter are new. Front tire is new as is the master cylinder. The tank is 81 xs400.. New starter installed and has stock air boxes. New gel battery. Original side covers. I need to get $1750.Basically just needs wired.
