ryanhall41
My bike was running great one day and the next morning took a turn for the worse.
The Issue: When in gear I have very poor acceleration, to the point where I can get the bike fast enough to get past 2nd gear in most cases. If I try to go to a higher gear I start getting all kinds of vibrations down low. I can feel them most prominent in my foot controls area. Also when in neutral or clutch pulled in the throttle sounds very crisp and responsive but in gear I get kind of a "chuff chuff" sounds when trying to accelerate.
Remedies tried so far: To start are ground zero I emptied the tank and put fresh 93 octane in it and I seemed to get a little more acceleration but nothing that would slide me back in my seat like it used to. It's a 1975 xs650 so it did not come with vacuum barbs and it currently had keihin pwk 32's on it. I installed the carb boots from mike's with the new vacuum barbs and re-synced the carbs via the manometer method. Again I got a little more to the point where 1st and 2nd feel ok but still not like it used to. I still get a lot of vibrations past second that almost feel like some serious chain slap.
What's the next step here? The shop I took it to in order to do the wiring harness and some final button up didnt like to use loctite and I've had problems with bolts rattling loose, is there any in particular that I should check that may be causing these bogging issues.
Sorry, I'm new to the xs, any help would be great
