mrriggs
XS650 Junkie
So far I'm liking them better than the BS38's that were on the bike. I still haven't got them tuned in [too rich] but I'm zeroing in on it.
I was getting a little weepage from the left bowl overflow so I pulled the carbs off to check the float levels. The floats in both carbs were set to 19.5mm. I'm assuming that is right since these carbs cam with no instructions. The nearest I could find online was for the 28mm flatslides (same carb, smaller bore) which has a float level spec of 19mm.
Looking at the float bowls, it appears that the overflow tube in the left bowl has been cut shorter.
It looks like a hack job, much rougher cut than the tube in the right bowl. You can't tell in these pictures but it also come out at a different angle which makes getting the bowl on and off very tricky.
To complicate matters further, the rubber bowl gasket swelled up when it got gas on it and popped out of the groove.
I had to hit it with a heat gun to dry out the gas and shrink it back down to size. In the future I will pull the bowls before inverting the carbs to prevent the rubber from getting wet. The first time I pulled the bowls (to change pilot jets) the carbs were still on the bike and I did not have the same issue with the bowl gaskets.
That's the best thing about these carbs. You can pull the bowls, change jets and needles without having to pull the carbs off the bike. You don't even have to pull the tank or air filters or nothin', it's all right there.
So, who else is running the PWK's [PUKES]? What is your opinion of them? Any issues, tuning or otherwise?
