The local bike shop didn't have the Banshee throttle kit in stock but it only took a couple of days for it to come in. I got the Motion Pro "Turbo" throttle kit #01-0345, $70.28 after tax. The "Turbo" has a little faster pull than the stock throttle, but still very streetable. The cable that came in the kit is much nicer than the Mike's cable. It's definitely not up to OEM standards but still seems to be a decent piece, works smoothly. The tag on it says "Universal Throttle" which should have been my first clue that it wasn't going to just bolt on in a few minutes.
The kit is listed as compatible with PWK 28 carbs and even came with the necessary adjusters to replace the angled adjusters on the Mike's cables. Unfortunately, when the cables were installed in the carbs, they were too short and held the slides open. To get some free play in the cables I had to file down the tops of the carburetor caps. This pic shows the left one filed down, right one to demonstrate how tall they were to start with.
The cables routed easily to the carbs. The housings and adjusters are more solid than the MIke's cables. They even have little rubber boots that slip down over the adjusters (not slipped down yet in the picture).
I ran the cable under the backbone, between the motor mounts, and straight out the front of the frame.
The cable is short so you need to have low and/or narrow bars for it to reach the twist grip.
I mounted the throttle and hooked up the cable. Wouldn't you know it, the "Universal" cable was too short for the "Turbo" throttle. With the adjuster screwed all the way in it was holding the slides open. I had to file down the throttle housing where the adjuster screws in, just like I did on the carbs, to get some free play at the grip.
With all that fun behind me, I hooked up the mercury sticks and synced the carbs at idle using the slide screws, then held it off idle and synced it using the cable adjusters. It seems to hold a sync throughout the throttle range. That is one thing I could never achieve with the Mike's cable. You could sync it right off idle but when you would open the throttle a little further it would be off by five to ten inches. Open it a little more and it would swing completely and be off by five to ten inches the other way. I was pulling my hair out trying to fine tune these carbs and it turns out it was the cables I was fighting.
I finished it right before dinner so I could only go on a short test ride. It is already running better than it ever has. I need to get some more miles on it before I'll know for sure how well it's going to work out.
