Shovel Jockey
Piano Tuna
I had to pull the engine from my stock early 78E for extensive repairs. I had a spare engine from a stock 75B and installed it. I am still using the 78 carbs and exhaust on the 75 engine. It seems to be running fine but I realize these are two different engines,(valve settings; compression ratios, plugs). Is there a possible problem running the 78 carbs on the 75 engine?
