So after installing the Boyer electronic ignition, replacing spark plugs, the motorcycle ran amazing, better than it probably ever has.
Last week it was about 38 degrees and i tried to ride it, it started with the choke on, i left the choke on a few minutes so it can warm up otherwise it kept turning off. After about 2 minutes it turned off on its own and wouldn't want to turn back on.
I recharged the battery, check the spark plugs (they looked okay), itll turn on with choke on but i have to keep revving it for it to stay on, once i remove choke it will completely shut off. After 2-3 tries of this it no longer wants to start at all until i use the kick start, then it seems to release and allows me to electronically start it again.
Any idea what can be causing it not to turn on properly anymore and stay on? any guidance would be great, im at my wits end, spent the whole summary dealing with the advanced spring system, then switched to electronic ignition, now this is happening, whole summer passed by with just issues, im frustrated.
Thank you.
Thank you.
