Thanks 5T, thought the light checker could be the problem. No led's tho, bike is stock except for pamco ignition and pma. Still don't know why the s/l relay is switching on and off so rapidly, just noted that trouble light flickering and rate of relay switching noise was synchronized with rpm's. I appreciate your response .btw, all my data has returned from wherever, mackeral I guess.Thanks again, and any input is always welcome.The dash light for brake and tail light failure isn't controlled by the starter/headlight safety relay, it's controlled by the light checker. Maybe that part has gone bad. What will also turn that dash light on is changing to an L.E.D. tail light bulb. It uses such a small amount of current that apparently the light checker thinks it's burned out.
Hello Leo, You're right. I need to thank you for that info. You are the one who solved the mystery of no headlight for me back in June when I did the xscharge initial install. I did do it that way and it worked fine. An hour or two to install and the spent the next two weeks between chasing wires ,testing circuits and looking here for an answer before coming across your post.(Still think companies that sell crap should know how to install it so that everything works properly). The stator and reg/rec didn't hold up though and during the subsequent time span I found a concise tutorial by by mrriggs and decided to do it that way when I got a used Kaw stator and a mosfet unit. I still had the stock rectifier. I am going to do over, quick and easy enough to do and less wire, the regulator has 12ga. wires . As for the relay switching on and off, I don't what's going on there. Am about to dive in here and hunt. Any knowledge imparted is welcome. Thanks againIn the diagram you posted in your first post, I don't see why you need the stock rectifier hooked in. Just hook the yellow wire to one of the wires from the stator to the reg/rec. This duplicates the way the stock system works.
That's right, according to one source I've read it takes about 6 volts ac to operate the relays. That original connection was tied to three wires in the stator though. I did disconnect the rectifier and connect with the one wire direct from stator to relay and switching was still occurring. At least I know the relays open and close. When the xscharge units failed something else must have been effected.Yes, I've never seen that method of utilizing a second rectifier to power the yellow wire to the safety relay. That could be the problem for one of several reasons. First, the original set-up ran the yellow wire directly from the alternator to the safety relay, and not through the rectifier. The alternator produces AC current or voltage. Passing it through a rectifier would convert that to DC voltage. Maybe that's the issue? Maybe the relay needs AC voltage to function correctly? Also, I'm pretty sure that yellow wire only tapped into one of the three phases in the alternator. That means it would only be sending 4 or 5 volts to the safety relay.
Hey Leo, Yesterday while sitting around waiting for a tornado or whatever else the clouds might bring , I went out to the barn to play with some old parts and tested the safety relay coils. I thought I might have toasted them by connecting them to unregulated alternator voltage. They both read around 25 ohms so I connected them to my charger and both checked good. I reinstalled one and it is working properly now, no chattering. The light checker or a circuit incorporated in it must have been the bug. No headlight switch needed now, Appreciate your inputIn my early Yamaha repair manuals it list the spec's for the safety relay cut out voltage of 2.5 volts or less.
With the testing I have done with AA batteries that is about right. One battery won't trip them, two will. I tested several of mine just to see. Some took 3 batteries.
As I recall you can take the cover off the relay and adjust the spring tension on the contacts to adjust the voltage that it trips at. Cleaning the contacts won't hurt either.
On the yellow wire, I don't think it's actually AC it's more of a pulsing DC. In the stator one end of each winding comes together and this is where the yellow wire hooks in. The other end of each winding goes out the rectifier. From the rectifier to positive and ground. The yellow wire goes to the safety relay then to ground. The only way it can get back to the stator windings is through the rectifier ground. If this current flow passes through the rectifier then it has to be DC.
For testing purposes you can get a 5 prong relay. most carts have plenty under the hood. they use them for fuel pumps, air conditioning, all sorts of things. I pick up a few every time I go to the salvage yard looking for car parts.
You can find the 4 prong versions in the stores but won't work for this task.
On the 5 prong relay the prongs are numbered. 85 and 86 trip the relay. power in on 30, power out on 87A when not tripped, this is the one you use. The 4 prong one don't have this prong. 87 is power out when tripped, this turns on things like lighting. the 4 prong use this one.
You can make jumper wire that hook to the relay then plug into the harness plug where the stock relay plugs in.
If this works then your stock relay is bad or needs cleaning and adjusting. If it makes no difference the your problem is elsewhere.
