For Sale - 80mm (742cc) Big Bore Kit for 256 motors w/22mm pin - New
andysrage
PA
*SOLD* 80mm (742cc) Big Bore Kit for 256 motors w/22mm pin - New
**SOLD**Brand new 80mm Wiseco Big Bore kit for the older (71-73) XS's with the 256 motor that use 22mm wrist pins. Should come out to 742cc. I bought this so many years ago I cannot recall the compression ratio but I believe it is 10:1; you can check with Wiseco using the piston kit number in the picture.
Includes:
2 Wiseco pistons with pin, circlips
2 set of Wiseco rings (not pictured)
2 Advanced Sleeve cylinder sleeves
Wiseco base and head gasket
I am parting with my cafe project since taking a job requiring extensive travel so time to finish it (heck, just start) will be come rare. Asking $400; Located in NJ.
This will not work with a 1974+ (447) engine because those have 20mm wrist pins and shorter rods. It would work if you swapped the longer 256 rods that accept 22mm pins onto your crank.
