TDodge7
Hey everyone , I've been lurking on here for a while but now I finally have a reason to post , the 81 xs650 that I've been getting back on the road for a friend of mine is running again but something isn't quite right . Since getting the bike I've done the following (plus a bunch of non engine related stuff that isn't worth mentioning here) :
new oil filter (and pan screen)
new oil
adjusted valves
adjusted cam chain tension
rebuilt carburetors
ultrasonically cleaned carburetors
adjusted float height to factory spec
synced the carbs with my morgan carbtune
currently running
Main jet 140 (132.5 is stock)
pilot jet 42.5 (original)
Air jet 135 (original)
Mixture screw kits from mikes xs (o rings were bad on the originals ) screws are shaped differently from stock but are the same length and appear to have the same taper as original .
mods
aftermarket exhaust (unknown brand , no brand names on it anywhere , seen in the picture below)
Mikes xs pod filters
Accel coil
Timing is correct
idle speed is around 1100
Checked everything for leaks with an unlit propane torch , no leaks found .
Here is where the problem comes in , I'm absolutely horrible at setting idle mixture , I didn't have an ear for it so much that I went out and bought a gunson color tune , the spark plug with the crystal window so you can see the color of your burn . Well it seems I also don't have the eyes for it either so I just got an older inductive dwell tach that reads the correct rpm . Based off that I used the dead cylinder method to set the mixture , watching for when I got the absolute highest rpm on the dwell/tach . The smoothest running and highest idle both came close to 1.5 turns out from lightly seated on the mixture screws . The problem is that While it sounds like it's idling pretty smoothly , there is almost no throttle response . Anything more than a smooth roll on and it tries to stall out for a second before revving up . Once it does rev it returns to idle without any hanging , and doesn't pop on decel . The plugs look lean to me , or at least very clean white , but I've always been horrible at judging them . Basically with the mods/jets I've listed is 1.5 turns out a reasonable place to be ? And what is up with the throttle ? I should be able to rev it a little faster than a roll on in neutral without it trying to choke out before it finally gets around to revving . Is it possible that I need richer pilot jets to compensate for the off idle ? I have a set of richer pilot jets I can put in if need be , also adjustable needles and mains but it preforms well everywhere but off idle.
here is a picture of my friend enjoying his first ride around the block.
new oil
adjusted valves
rebuilt carburetors
currently running
mods
Accel coil
Timing is correct
