Ok , so all the parts are in , original epa screws are back in the carbs with new o rings in the proper order this time . So first I do the dead cylinder method entirely by ear , which gets me to 3.25 turns out on each side . Then I got out the dwell tach and tried again , again the highest rpm I can get comes between 3.0 and 3.5 turns out . Then just for over kill I got out the color tune to make sure , at 2.5 turns it's lean , at 3 it's nice and blue , same with 3.5 , and then by 4 it starts going yellow indicating that it's getting too rich . All of this sounds great , it idles well , throttle response is fairly crisp , and after a rev it quickly returns to idle . But , the right cylinder seems to pop on decel . The header nuts were a little loose so I tightened those up but it still seems to do it , the exhaust gaskets are new . As you're engine breaking it gets down to the 1500-2000rpm range and you can hear it crack in the right pipe a few times , always on the right side . Granted these pipes are pretty free flowing and some mild popping on decel is normal , but sometimes you can hear the difference between the normal decel and these pops . Both cylinders reacted the same way to the same number of mixture screw turns so I find it hard to believe that the right cylinder is lean and the left isn't . I can't find any exhaust leaks , carbs are synced , valves adjusted , cam chain tensioned , it's an 81 so the timing can't be off , I've even tried yelling at it , is there something I'm not thinking of or am I just being paranoid and trying to find a problem that isn't really there ?
