Working through an issue with the Starter Lockout Relay Logic. I know my relay has a bad diode in it. Bike will start in neutral and can ride it through all the gears but when the bike is in gear and the clutch is in it will not trigger the relay and send power to the starter solenoid. Not an issue with the side stand and I have rang out all the wires and switches and they seem to be doing what they are supposed. I know the issue is the relay but the drawing below shows a second diode in line somewhere. Anyone know where this diode is located? When I run a continuity test on the Sb (Sky blue) wire from the relay and get different readings in resistance if I switch the probes around between the wire and ground. I have not run a diode test on the wire yet but does this diode even exist in line (other than the one in the relay). My readings seem to indicate that it does but frankly not sure where it would be. I want to rule out this as another possible issue with the control. I want to retain the clutch, sidestand and neutral switches operational...I am funny that way.
I tried to source a new relay but not worth the $100+ CDN for an OEM and the aftermarket one I ordered on Amazon for $15 was not the right one even though they said it was. No diode in it.
Thanks
Thanks
