Paulrxs650
I thought I would start a seperate thread on this.
I have rebuilt the engine and honed the bores lightly. the rings were in spec, so were reused and set with gaps at 120 degrees to each other. All seals and gaskets replaced.
Just noticed on cold start up that I am getting a little blue smoke for 30 seconds or so from the left pipe. Popped the exhaust off and carbs and wiped down the valve stems. Left it overnight, and there was no oil on the stems, so that made methink its not valve stem seals (they were replaced in any case). Popped the tank off and re-torqued the head. the bike has done 150 miles and the chrome nuts certainly needed tightening. Torqued to 26 ft/lb then to 30 ft/lb (as recommended by a few people on here). Started it up and still had a bit smoke on, then cleared away. Plugs are oily but then clear up straight away and look perfect after a run. Compression off the kickstart when warm is 135 - 140 each cylinder even.
I am suspecting either, rings not seated or head gasket issue - thoughts please?
