CoconutPete
1979 XS650 Special
Here are a few clutch safety switch questions I have gathered.
1: My bike is a 1979 Special. Does it have one? I see no wires from the clutch. Wondering if a PO removed it, or if it never had one.
2: The 2 wires in a clutch safety switch. When the clutch is pulled, does that create connectivity between the 2 wires or break it?
3: In a factory state, does it tie into which gear you are in? In other words, do you need to pull the clutch in to start the bike in 1st gear, but you're free to start it without pulling the clutch in neutral - do I have that right?
In case you are wondering what the hell I'm doing: I am converting the automatic headlight to have it's own on/off switch and my safety relay is kaputt, so I'm replacing that as well and I'd like to tie the clutch into the starter button to at least have a little protection from accidentally hitting it. Hence the wire connectivity question.
