Okay folks, short and sweet:
First of all, I had my TCBROS hardtail welded on this morning. Turned out excellent. I also ordered the rubber mounted sportster gas tank from them as well which came with mounting hardware but no instructions. Now I'm not a total loof that can't figure anything out, but why is their 7 (odd number) washers, and one bolt is about 6" long while the other is about 4", and the steel-sleeved-grommets.... ? Does anyone actually know how it's SUPPOSED to work or is it just some random stuff to play with and slap something together?
Two: I'm trying to get her running, and I know she will, but I need to know a few things (and wait for my pamco in the meantime). What is the light blue wire that goes to the sensor in the top of the crankcase on the rearward left hand side? It is joined to the wiring that comes from the alternator, and goes into the same white quik-connect plug as well. Is it needed? Because mine is cut off at the sensor, and I have no idea what purpose it really serves anyhow.
Three: What is the correct way to space a mag wheel with a drum brake on the TCBROS hardtail? Run to the hardware store and pick up 5 pounds of washers and play with it til she fits? I have exactly 8.5 inches between the two plates. Does the stock spool-looking spacer get used here?
Lastly: When I get the Pamco (Part # 14-0902) it has everything but the condensor and battery required to run the bike, is this correct?
THANK YOU!
Logan
THANK YOU!
Logan
