I'm putting my top end back together, and have run into an interesting issue. During disassembly, it appears I ended up with an extra short pin for the centrifugal advance rod. I did not take the points cam end apart. The long pin goes in the camshaft, the short pin goes into the advance rod to engage the disc. The long pin will not fit there, I tried that thinking maybe the pin broke in half somehow, but it is way too long. It will only go one way, the hole in the advance rod must be tapered, but it engages the disc just as it should(the short pin). I have no idea where the other short pin would go. Now- when I was taking the motor apart, at some point after removing the head and cyls, while rolling the engine around, a small pin fell out and hit the floor. I accounted for all the pins when I disassembled the advance(I thought), so when this extra pin appeared I was baffled but figured it would become obvious where it went. Well, it ain't obvious(to me, anyway). Did someone leave it in there during a previous teardown, or am I totally missing where it goes? Thanks!
