So I'm about 150 miles into a fresh top end rebuild, just re-torqued the head bolts, getting ready to do 1st oil change and valve adjustment. Bike is running great, but is a bit lean based on the plugs and a wee bit of hunting at steady throttle. Idle is pretty stable, but once in a while will hang at 1600 or so, I've got the stops set at around 1200-1300. It is possible I have an air leak somewhere, but I've also got a much less restricted muffler set than stock, so jets are also suspect.
The advance weights seem free, and want to snap back, but it is the actual advance rod that seems to have some resistance keeping the weights from snapping back. I put a little fresh grease on the bushings when the head went back together, and the rod seems to turn freely, but not "frictionless" to the level that the advance springs would pull it back to full retard. Now, these springs are 40 years old, so they may be tired.
What are the pitfalls if I tighten up the springs and can't get full advance out of 'em? Is this likely, or do the weights have enough mass to overcome a slightly stronger spring? Seems to me I should be able to rotate the advance rod by hand to the limit, and the springs should pull it right back to the stop. Now, should I expect this same snap back when the engine is at 50 deg. F and the oil/grease are cold as I would when it is fully warmed up? Or is it reasonable for cold grease to influence the movement of the advance rod?
As stated above, bike is running great, pulls strong, no flat spots, just the "tickle" at steady speed and the occassionally hanging idle. Stock airboxes with filters, but the mufflers don't have much in 'em. Thanks!
