Aftermarket Master Cylinder Vertical pedal travel
Oddjob
adsgads
Burnaby, BC
For those hardtailed folks using this common aftermarket rear disk brake master cylinder (MikesXS Part #08-4002) how much pedal travel to you typically have after hooking everything up and bleeding the system...
For those running a stock disk brake MC how much pedal travel do you guys have...
I'm trying to figure out how much room I have for running exhaust under the foot pegs/brake pedal...
Pictured below is my current mock up with the disk brake pivot shaft...
