Michaelo
650Mick
Drop a DC volt multimeter over your battery check voltage, then start and take from idle to 3000 rpm, watch the voltage increase.....this is where the variable between bikes charging is, but you can rest easier knowing that there is charge present and charging your new battery. I've done the same as you (except the 600 grt) have and mine is charging around 1.8 volts above the idle voltage from memory.
A fully charged battery (correct me if I am wrong) will have most of the charge coming from the rotor / stator dumped through the regulator, so it will appear on the volt meter not to be charging very much at all where in actual reality its just been dumped through the the regulator and into coil that sits directly next to the regulator....hope that makes sense....
Nothing wrong with rotor / stator charging system on these, just maintain it....
