First thing I done on the bench was the slap test I passed 11 volts from an old battery through the rotor and it picked up a screwdriver from over 1/2 inch away got 5.3 ohms on both slip rings, the stator is giving out less than 0.5 ohms on each wire, the wires to the tips of brushes 0.4 ohms, what I noticed with fully charged battery on the bike is less than 1/2 a volt getting to the brushes through the green wire which is a switched live from reg/rec also tested.
The main harness has always been a mess and I have rectified some of this I have bought a new one from mikes xs to be put on over the winter, what I was really wondering was if at the rotation speed of 900 rpm the 9volts would be acceptable with the hope that when all back on the bike and 12 volts getting too the rotor and correct idle speed it would give out what it's supposed too, I guess I will have to wait and see, I do have a PMA which I have had to send back already as two of the stator connections had come apart, I may as well ask now, instead of using the rectifier that come with the PMA is it feasible to put the PMA through the new harness where the original alternator would have been plugged in to save having to cut into the new harness or extending the rectifier leads so I can place it in a cooler spot as the new one is much larger.
