I know there have been issues with the Gonzo boxes not working correctly so I thought I would post my recent experience. I bought one of Jim's Gonzo pigtails (thanks again Jim) about a year ago but never bought a box to try as there seemed to be lots of problems with bad boxes coming out of China. My TCI is still working fine and I wanted the Gonzo only as a backup to have on the road in case of a TCI failure so I figured I would wait and see if the bad boxes would sort themselves out.
I recently bought a Gonzo on Amazon for just under $10 and upon arrival last week it was DOA. I debated returning that one and trying another vendor vs getting a replacement from the same vendor. I opted for a replacement which showed up today. This one fired up on the first kick and the advance seems to be working as it should although I didn't verify I'm getting the full 20 degrees advance as it will do what I want and I wouldn't adjust the timing anyway as it's set where I want it (a couple degrees retarded) for the TCI.
This is the Gonzo I bought...
It was $9.94 when I bought it but has gone up since. I expect if you wait it will go back down again.
I'm tempted to check/set the full advance and run it for a while to see if I get an "infant mortality" failure or if it might actually last. IIRC Jim has been running his for a while without issues so hopefully they are reliable once you pass the obligatory QC field inspection for the Chinese manufacturer.
