Went back over @jpdevol suggestion.If I may suggest; One of the first things I'd do, given your symptom, is remove the pods and check for proper diaphragm/slide operation: start it up and peer into the bell and verify the slides are lifting with rpm. If not, or if they flutter @2000, press the choke rod in (attempting to overcome a leak) and see if the slides respond. Otherwise I'm also paying particular attention to the diaphragm operation (14sec drop test)
OK returned to the carbs and decided to disassemble and clean yet again; no issues found.
On reassembly I did the slide drop test; and low and behold the left slide was just falling too quickly.
Took out the slide again and rechecked the diaphragm with a very bright Milwaukee LED pen light:
A tiny pin prick hole in a crease of the diaphragm; easily missed.
I'm hoping I have found the issue now with getting over 1/4 throttle.
I will have to source a new diaphragm / slide to fix this.
Ads.
ACBUILD
worse that before the swap. Aaaaarggghhh!!!! Returned to the shop; put her away and went to the pub
