So I'm rebuilding a spare motor. 1981. Checking the connecting rods big end side clearance I'm getting closer to .58mm, and the max spec is .40mm. Side to side at small end is within spec. Does that mean the crank has begun to separate? Big end bearings seem tight otherwise. I'm a firm believer if you're going to do something, may as well do it right. Should I just run it, or am I better off sending this out for rebuild or for those DIY-ers, how difficult to split, re-press, and true up the crank? Already split the cases to put a 5th gear overdrive in (that part is done). I do have a press, but have read a lot of threads on the ins/outs of rebuilding a crank on your own and truing up the crank is the tricky part. Just looking for advice from those more experienced. Never done a crank before....
